new tires. help please
I've got a 96 f-150 4X4. i am wanting to put tires on in but i cannot imagine what things would look like. could ya'll give me some ideas that would look good on the truck. if possible i would like to put 35's on with a 3'' lift but i'm not quite sure how it would look. if it helps its a short bed single cab. thanks
Assuming you are referring to a 3" BL. If you did that with 35's it would look good. The big question with tires is how much do you want to spend. I am guessing you have a 16 inch rim and if that is the case that will cut down on cost.
