Wheel fit question.
Old Aug 6, 2009 | 09:09 AM
PhatCatDM's Avatar
Wheel fit question.
I know I know... Not another wheel question. I have found a set of wheels with the following specs. I have plans to run 33X12.50 ish tires in a 17 and want to run a 2 in level kit. Will these be ok with the backspace and offset?
Part Number: PXA9089-7936
17x9, 6 on 135mm Bolt Pattern
Backspace = 4.75 in.
Max Load = 2200lbs
Finish = Knight Chrome
Hub Centric = No
Offset = -6mm
Running this on 05 4X4 SuperCrew
THanks
PhatCat
Old Aug 6, 2009 | 12:34 PM
wandell's Avatar
Yes, they will fit. That wheel will stick out 2 1/4 inches farther than your OEM wheels.
Old Aug 6, 2009 | 12:43 PM
PhatCatDM's Avatar
Cool... Thanks!!!
So a 295/70/17 should be fine on it with these wheels. Correct?
Old Aug 6, 2009 | 12:49 PM
wandell's Avatar
Yes.
