AHHHHH What Am I Doing Wrong?????
Ok I've been trying to get my drivers side rear rotor off for the past 2 days. Ive sprayed it with a ton of PB blaster and ive been hitting it with a rubber mallet and using a crow bar on it and it wont budge.
To make sure.... The only thing that needs to be removed off a rear brake rotor for it to come off is the brake caliper right??
I took the little rubber stopper thing off the back of the brake and theres a little star thing that i turned. Im guessing that is the aduster???
Well Its that time. Ive been defeated.
All I have gotten out of this is a sunburn and grease stained fingers. haha. I guess i got to call a mechanic. Thanks for everyones help.
I would try some heat and a biger hamer. My buddy had the same problem on his 2000 f150 front rotors. Ford is known for using such tight fit on their rotors. Good luck.
P.S. I have to asume you are buying new ones so hit it like you have at set.
