Which offset/backspace will stick out the least?
Old Jul 30, 2009 | 03:26 AM
slimcubby's Avatar
Between the two choices which one will stick out less.
-6mm Offset / 4.75" Backspace
0mm Offset / 5.00" Backspace
Old Jul 30, 2009 | 04:25 AM
shawnp's Avatar
0. Go with a +18 or 35 if you can.
Old Jul 30, 2009 | 07:06 AM
HighOn22's's Avatar
Do you have a 4wd or 2wd? If it's a 2wd and you're going to level the back then go with +18 or +35 as said above, but if it's a 4wd then gor with the 0 or +6 offset. The +6 will stick out more.
Old Jul 30, 2009 | 11:31 AM
slimcubby's Avatar
I have an FX4 4wd. So for the above would the 0 offset/5" backspace be the best choice of the two for sticking out the least?
Old Jul 30, 2009 | 12:09 PM
wandell's Avatar
Can't answer the question without knowing the width of the wheels. If the wheel width is the same on both wheels, the one with 5 inches of bs will tuck in more. But like I said, can't tell without knowing the wheel width.
Old Jul 30, 2009 | 08:18 PM
slimcubby's Avatar
They are both 18x9's. Ok now that I know the 5" backspace is the way to go I just need to decide which tire size lol.
Either 305/60/18 or 325/60/18 Nitto TG's.
Old Jul 31, 2009 | 11:35 PM
HighOn22's's Avatar
If the 325 fits without rubing I'd go with it. A wider tire will look better, but I'm almost sure it will rub. I have a set of 325/50/22 in my shed and they're 13.5" wide.
Old Aug 1, 2009 | 09:31 AM
wandell's Avatar
Several members are running the combo he asked about with no problems.
