help with wheels
You are outta luck. If you use a 16x10 with 4.5 inches of backspacing, you can fit a 35x12.50. It's a pretty tight fit and you will have to do some minor trimming of the front bumper's lower plastic valance. This combo will put the edge of the tire/wheel just about even with the edge of the front fender flares. The only way to get the tires to stick out will be to use a 12 inch wide wheel, which is rare, and then you will need more lift to fit the 35's.
yeah havent seen many 12's but you gotta start somewhere right. they will work for now b/c after the first of the year funds permiting im going to do a strait axle con. i have all the major stuff plus 14in of lift that come out from under my buddy's 250. he went with a diff setup and gave it to me but you know how m o n e y can get sometimes.lol
