Burnt Smell from Front Tires
Old Jul 21, 2009 | 10:44 PM
BigDawg99's Avatar
i just installed a Brand New set of Front Disk Brake pads on my 2004 Ford F150 FX4 4x4..A day later i am smelling a real strong Burnt smell coming from the front Drivers Side RIm...ANd with the new brakes...you can hear a Swishing sound coming from the front....can someone tell me what is going on..
Old Jul 21, 2009 | 11:37 PM
Maxout05's Avatar
could be a number of things but most likely things are dirty/rusted caliper slides causing hang ups, warped rotor, dirty brake pads, air in fluid.. Best thing to do is to remove it all, service the caliper slides and grease them, spray brake kleen all over pads/rotors and make sure they are clean and take it from there. Chances are the rotor needs to be replaced though.
Old Jul 22, 2009 | 09:25 AM
mdhawkin's Avatar
The swishing sound is the pads and the rotar making contact as the wheels spins. It clears then hits clears then hit etc. Chances are you have a rotor that is slightly warped, depending on how bad it is and how much use you have gotten out of them you may want to repair OR replace them.
When you brake hard I am willing to bet you feel a shimmy/vibration?
Old Jul 25, 2009 | 03:05 AM
TX_FX4's Avatar
First thing I would do is clean it all out. If that dosent work I would go with new calipers.
