came stock with 18"
I GOT AN '05 FX4 AND IT CAME WITH STOCK 18' RIMS I WANT TO PUT NEW RIMS DO I NEED TO PUT THE SAME SIZE OR CAN I CHANGE( GO SMALLER NOT BIGGER)? MAY SOUND STUPID BUT JUST CURIOUS.MY BUDDY CAN GET ME A BITCHEN DEAL ON KMC WHEELS AND HE SAID SOME 17" BEADLOCKS AND 35'S BUT DIDN'T KNOW IF 17'S WOULD FIT CONSIDERING IT CAME WITH 18". i FIGURED THE FX4 OR 4X4 CAME WITH BIGGER ROTOR AND BRAKES SO THEY WOULDN'T FIT 17'S AND SOMEONE I WA TALKING WITH SAID THAT 15'S WOULD FIT,THATS WHY I'M CURIOUS. THANKS IN ADVANCE....
you can do any size wheel you want as long as it is 6x135 bolt pattern...you will need to change the tire to keep the height of the truck the same..
17's and 35's are going to require a leveling kit
thanks for the replys. and i do plan on up grading the sus. going to put an upper arm and kings up font and kings in rear soon. just wanted to know more about my tire options that i can run.. now for your opinions 15" 16" 17 " 18", 18" are the biggest i want to run but what do you think about 17" with 35's?
17" and 35" are a good looking combo. Makes for a good bit of rubber showing, looks mean. Make sure new upper arm does not interfere with tire as its still not a full suspension lift angles could lead to some rubbing.
I know that was true with the Gen III like yours. I just got rid of mine like yours that had 7" lift and 37's for a 05 Super Crew. I just put on one of my wheels on a buddy's truck that had a flat and he was in a bind because is spare was flat. I have 17's on my truck he has 18's and it worked just fine. Got it to my house and fixed his tire and he was back off. He drove about 25 miles on my rim and tire and it did no damage.Just reread your post, and saw you meant you CAN fit 17's on it. My bad, carry on...
Last edited by Super-Crew-2005; Jul 22, 2009 at 09:55 PM. Reason: Spelling *dumb* Re-read your post and feel dumb. I can man up! :)
I figured something like that. i figure that the brakes were 15" or 16" rotors i think, so no smaller than 17"
