wheel help
Old Jul 17, 2009 | 10:28 AM
jarrett150's Avatar
wheel help
hi, iam new here and need a little help with some wheels. they are 16 x 10
4.5 bs extreme alloy 6079. will i need any spacers or lift? and what is the biggest tire i can run w/o any problems , just an all terrain tire nothing fancy
thanks in advance
Old Jul 17, 2009 | 10:35 AM
chris_w_2008's Avatar
im asuming its a 2002 ford f150 4x4? if so you can crank the torsion bars and fit i think up to 33's with a little trimming to lower valance, i did some searching when i was looking into this.
Old Jul 17, 2009 | 11:35 AM
jarrett150's Avatar
thanks for your help , im sorry its 2wd , i was thinking of maybe a 285 70. now how bout the wheels any problems.
thanks again
Old Jul 17, 2009 | 11:37 AM
kingfish51's Avatar
Yes, the wheels will be too wide for a 285/70.
Old Jul 17, 2009 | 11:59 AM
jarrett150's Avatar
will the wheels work? and what size tire with no mods
Old Jul 17, 2009 | 12:32 PM
wandell's Avatar
You can use those tires with 285/75-16(33x11.50) or 305/70-16(33x12.50) tires. However, they will not fit without a lift on your 4x2. If you add a 3 inch body lift you can fit 33's by trimming a little plastic off the front bumper's lower valance. Personally, I'd also add a set of Daystar coilspring spacers to level the truck. THis will put you at the same height as a stock 4x4 with the torsion bars cranked up.
If you do not want to lift your truck at all you need to go down to a 16x8 inch wheel. I'd suggest a 265/75-16 (32x10.50) tire in that case.
Old Jul 17, 2009 | 01:38 PM
jarrett150's Avatar
thanks so much to all
