99 Rear Rotors
99 Rear Rotors
Do I need to unhook the emergency brake cable to change the rear rotors on my 99' 4x4 ? I was changing the pads and just tried to take it off and tap it a little and it wouldnt budge. Has anyone ever changed theres?
No to remove the rotors you should not have to remove the cable. However, just like on a set of drum brakes, you will have to back off the e-brakes since a ridge of rust is probably holding them on, along with other rust at the hub.
