17 - 18- 20 ??
17 - 18- 20 ??
'06 FX-4 scab
tires are gone & have to do something
Questions....
there seems to be more selection for 17 & 18 inchers than for OEM 20s
any dissadvantage in dropping down in size and going with larger tires
specifically Brake heating etc ???????????
Questions....
No disadvantage as long as you stay close to the same overall diameter on the tires, so the speedo will not be off. That is, unless you have a tuner and you can sdjust the speedo.
Here's a couple of stock oem sizes for you.
275/65r18
265/70r17
On stock oem rims for that tire size.
With squish accounted for there really shouldn't be any need for speedo adjustments.
The same brake rotor size is used from 17-22 rims
275/65r18
265/70r17
