Noob to the Wheels world
Old Jun 29, 2009 | 11:07 PM
MTXThunder9500's Avatar
Sounds like you are trying to explain offsets. - offsets mean the wheel will stick out past the fender some, and + are closer to OEM, a +18 offset is usually the best way to go.
i understand the offset thing but the rims im thinking about getting (XD Rockstars) on rimzoneonline.com show either a -0 offset or a +0 offset whats the difference between the two or isnt there a differance.
Old Jun 30, 2009 | 11:52 AM
wandell's Avatar
-0 and +0 are the same.
Old Jun 30, 2009 | 05:33 PM
ZSK's Avatar
ZSK
Are the 04+ F150's hub centric or lug centric?
Old Jun 30, 2009 | 10:42 PM
wandell's Avatar
THe oem 04-08 wheels are hub centric but most aftermarket wheels for them are lug centric. You can buy hub centric rings to use with lug centric aftermarket wheels.
Old Jul 1, 2009 | 10:51 AM
mtordie's Avatar
I am having a hell of a time getting my wheels to balance properly. Would this have anything to do with it? Wheels balanced but being mounted wrong?
Keep getting different opinions from different shops. Static balancing is the problem. Rim is bent. Tire is bad etc etc... At highway speeds the steering wheel shakes.. Which means problem was in front. Balanced tire and moved to rear now rear still sakes. Got new rim and tire and while not as bad truck still shakes.
Latest I got is now the other 3 rims need to be dynamically balanced like the new one..
Old Jul 1, 2009 | 12:06 PM
wandell's Avatar
Some members have reported that hub centric rings solved their vibration issues. I'd try them and also have the tires road force balanced.
