tpms
The 09's have the valve stem type. If you take the sensor off the OE wheels, you will just need to get new valve stems, pack of 4, part number 9L3Z-1700-A. If you go with new sensors, you will need the kit of sensor and valve stem, part number 9L3Z-1A189-A. You will need 4 of those. You will also need to retrain the vehicle to which sensors you have. Transmitter is part number 8C2Z-1A203-A.
You can sometimes find any of these on Ebay, or for a little more, order them from Tasca or some other dealer. Not as expensive from Tasca as you might think.
Note these part numbers are only for the F150 as far as I know, but may be the same for the Fusion.
