TPMS Light
Old May 22, 2009 | 12:30 AM
itsmevin's Avatar
TPMS Light
I did everthing I was supposed to regarding the TPMS Light when I installed new wheels and tires i.e. bands and used the reset tool, it should have worked but the light came on (or would never go off!) so I got sick of it. For those of you out there with a strong stomach you can remove the connection from the cluster circuit board here is a picture of the culprit! Oh! I haven't posted enuff or somethin' to post Pics. I guess I'll work on that and add to this if and when get permission. Sorry!
Old May 23, 2009 | 11:14 AM
animated_zombie's Avatar
my dash light drives me completely bonkers.
you should do a write up on how to remove the light.
oh, even though you don't have a high enough post count to post pics quite yet, you can still host them at photobucket or something of the sort and link them over. to be honest that's still what i do most of the time anyway...
Old May 23, 2009 | 11:43 AM
chaos08's Avatar
My light came on the first day and then stopped. I did not put any sensors on my new wheels.
Old May 23, 2009 | 11:50 AM
BayouSupercrew's Avatar
For the O.P. you better hope one of your sensors did not come loose and is spinning around in your tire!! I imagine that would cause the light...??? The only other thing I can think of is you did not put the sensors facing in the correct direction (they have to face toward the outside where the valve stem is and they are directional) or one of them has a bad battery...???
