brake noise help!!!
Old May 17, 2009 | 06:11 PM
rprontosigns's Avatar
brake noise help!!!
hi my truck 2004 screw 4 dr lariat 2wd, 60 000 miles, question= any body can help with nose like something blowinf coming from brake pedal every time a brake and even more if i keep pushing pedal after truck has stopped, it is very annoying, please help by the way brake very well.
Old May 17, 2009 | 06:15 PM
forgot to mention all brakes are new ceramic, great braking no dust at all no noise,sweet just the noise inside cabin
Old May 17, 2009 | 06:30 PM
broncobran68's Avatar
Did you replace your rotors or have them resurfaced? Were they in good shape? Did you bleed your brakes or push on the pedal a hundred times to seat the pads on the rotors? Does the pedal feel firm or is it squishy?
Old May 17, 2009 | 08:59 PM
resurface rotors where en very good condition all brake job was done in a brake shop, did good job all ceramic pads all around, i even break/in the pads
Old May 18, 2009 | 11:13 PM
dlongoria's Avatar
My 05 did this before and after I replaced pads and rotors. It kept doing it. Read a post on here some time back about a recall/tsb Mazda ( I know) had out for this noise that called for flushing out the brake fluid. Figured what the hell and had it done at the dealer (at my cost). Some people say to flush brake system every two years others say leave the fluid alone. All I know is it took care of the problem. It makes no sense to me, but I don't care.
Old May 18, 2009 | 11:34 PM
gbaby002233's Avatar
have you brought it anywhere to get it checked out
Old May 25, 2009 | 04:42 PM
i took it to dealer charge me 100 for dx, came out brake booster was bad, they wanted 504 to do the job. or bring them a bbooster and charge me 200 labor so i call the dealer from whom i bought the truck and the guy at parts sold me a booster for 195. then on my way there i stop a midas they check it and the booster is ok no leak so im waiting on tmorrow to see if i can return the booster
like i said brakes excellent and they say its just ruber making noise. if they dont take it back ill install it my self, its a simple instalation process or ill put it on ebay. thanks ill keep posted.
