Wheels and tire combo
Old May 10, 2009 | 12:04 PM
eng4twrff's Avatar
I am getting ready to order this wheel and tire combo online I have a 2005 F150 4x4 stock ride height. I have been wanting to upgrade the wheels and tire for quite some time now. Here is the combo i am going to go with
Wheels-Motometal Series MO951 Wheel,17x9, 6 on 135 Bolt Pattern,Backspace 4.53 in
Tires- Nitto Terra Grappler NTGAT -LT295/70R17 Overall Diameter = 33.19 inches
I have been doing the research for a few weeks now pricing, trying to figure out if its going to fit on the truck and not rub and make sure that I am going to have enough clearance. I am a little nervous on dropping 1500 bucks on wheels and tires and them getting here and it not fitting right... So I am curious if this will work or if anyone else has any suggestions. Any help would be greatly appreciated!!!
Old May 10, 2009 | 10:52 PM
wandell's Avatar
If you add a leveling kit they will fit without a doubt. You may have some rubbing without one. Personally, on a 9 inch wide wheel I'd want at least 5 inches of BS.
Old May 11, 2009 | 07:49 PM
Misplacedtexan8's Avatar
Put on a leveling kit it will even out the truck and look good. 33's will fit and if you wanna to go a little bigger you could as well with the leveling kit.But good luck man.
Old May 11, 2009 | 09:35 PM
KR-Texas's Avatar
The wheels are going to stick out pretty far for a truck without a leveling kit. I have a 2" AS lift and here is a picture of my 18x9s with 5" of BS. I have the 33x12.5 Toyo MTs, so a 295 is a little narrower tire and the AT will have a less aggressive tread.
Before I trimmed the plastic, they rubbed on the outside edge of the driver side valence when I went in reverse. Yours will stick out a 1/2" further and without a lift will probably rub in the same place.
KR-Texas
Old May 12, 2009 | 02:59 PM
eng4twrff's Avatar
I want to thank yall for all the input. I placed the order yesterday, I also ordered the 2.5" leveling kit for the front... Hopefully it will all be here by this weekend Ill post pics as soon as I get the whip all togahter. Thanks agin!
