StopTech Drilled/Slotted Rotors... sexy
These things are sexy.
I know all the complaints, they'll crack; they'll break; they'll create a rift in the space-time continuum... so don't hate.
Once the weather clears up, I'm popping these babies on.
interesting drill holes.... the bottom set on the left of the picture has 4 holes then 2, all the rest of the sections have 4 and 3..... maybe they do that for balancing?
congrats, i have some slotted rotors on order. I had some slotted rotors on my first 03 and loved them. I personally dont care for the drilled, but slotted rotors work very well.
Each hole goes through one of the vents between the two plates. Between each slot / drill / drill combination, there is one vane that isn't drilled (which also happens to be the center of the slot). It appears that when they get around to the final combination, they only drill 2 holes to keep the one vane that isn't drilled.
i just ordered drilled and slotted front rotors from rotorpros for $300 with hawk pads, i got these because my previous set from them exactly the same lasted longer then stock, yeah there are some hair line cracks just like all rotors but they work a hell of a lot better
