Help me choose tires.
OK, so its getting close to time to buy tires again. The sad part is, I just got these tires in August. (I started with 16/32 and last measurment at rotation was between 7 and 10/32 on all tires) And I have less then 20k miles on them (Mostly Highway). I have 265/70/17 BFG AT KOs and I have had them rotated every 5k. I think the load range may be too light judging by their size, the amount of weight I add through tools or towing, and how fast they wore.
So what do you all reccomend as a new tire. I do need an aggresive tread for work and probably need to go up in size and load rating. I have a 3" procomp level and an AAL with Stock rims. So help a brother out.
FYI, I was considering KM2s 35/12.5/17. So, somewhere around $900-1300 is ok. I just want them to last a little longer. and I just checked and mine are load rated C. Thanks in advance.
