325/65/18 dune grapplers?
Old Apr 30, 2009 | 08:03 AM
msa4x4's Avatar
I have a 2005 F150 4WD fx4. I just installed a 3" Ready lift leveling kit and i am awaiting tires. I talked to a tire guy and he said 325/65/18 will fit with some rubbing. i am keeping my factory rim also. Will the 325/65/18 dune grappler fit with some rubbing, or will it rub too bad to mess up the tire?
What size is close to a 35 that will fit?
Old Apr 30, 2009 | 10:38 AM
wandell's Avatar
Yes, it will fit with minor rubbing. However, a 325mm wide tire is too wide for the OEM 7.5 inch wide wheel. That tire is essentially a 35x13.00-18. I'd go with something narrower. A BFG 305/65-18 (34x12.50) would be a good choice.
