Will this fit??
Will this fit??
http://www.4wheelparts.com/Wheels/Xt...n=PXA8115-2936
I have looked thru 4pages of backspacing threads and nothing....Have a headache now. Could one of the wheel fitment gurus please let me know if this wheel will work? The backspacing is what I am concerned about. I have a 2004 FX4 with a 2.5" leveling kit. I am currently running stock 20"s with 305/55/20 Terra Grap All terrains. Looking to stay with the same tires till worn out. Thanks for helping!!
Will the backspacing not swallow up the control arms and all? I am *almost* rubbing my upper control arm now with the top side of the tire....
The stock 20, as best as I can tell is 8.5" wide. With the wheel in the link, it is 9" wide. I just want to make sure that it won't rub....before I pull the trigger...
I don't know what else to tell you. I don't see a problem with the wheel/tire combo you want. Like you said, the oem 20's are 8.5 inches wide with 6.5 inches of backspacing. The wheel you want will just stick out about an inch more. I've seen members run similar tire/ lift combo's with wider wheels with a lot less backspacing with no problems.
