questions...
Old Apr 1, 2009 | 07:30 PM
rwenycevokal4's Avatar
questions...
Im kinda new to the tire and lifting thing...but im looking to lift my truck and add bigger tires. so far i have a 2.5" leveling kit. how big can i go on that with tires? rim size isnt too important to me but i would like a wide tire but no rubbing whatsoever. anyone?
Old Apr 1, 2009 | 10:09 PM
wandell's Avatar
4x4 or 4x2? If it's a 4x4, I'd suggest a 33x12.50 tire and a set of 9 inch wide wheels with 5 to 6 inches of backspacing.
Old Apr 2, 2009 | 05:29 PM
its a 4x4 any brand or examples i can look into?
Old Apr 2, 2009 | 09:59 PM
wandell's Avatar
For tires, I'd recommend a quality all terrian radial like the BFG AT KO, Nitto Terra Grappler, Toyo AT, Pro Comp Xtreme AT, Mickey Thompson ATZ or **** Cepek FC II. Whether you want a 17, 18 or 20 inch tire is just a personal choice. I like a lot of the Pro Comp, KMC, Moto Metal, Eagle Alloy, Mickey Thompson and **** Cepek wheels.
Old Apr 4, 2009 | 09:14 PM
joker1213's Avatar
2.5" leveling kit, 305/70/16 mickey mtz, 16x8 **** cepek dc1's. just to give you an idea...
Old Apr 6, 2009 | 02:32 PM
any rubbing with that?
Old Apr 6, 2009 | 09:22 PM
joker1213's Avatar
negative, very minor trimming on the lowest portion of the front bumper...and the rub issue would have been minimal...im just picky. lol trim took about 2 minutes with a sawzall. you can see it in the picture.
Old Apr 6, 2009 | 09:59 PM
you think its probably the same with a 2008? i would think so right? and thanks for your help
Old Apr 6, 2009 | 10:29 PM
joker1213's Avatar
no problem man, if anything the 08 might sit a little higher, i dont know if you have the fx4 or whhat, my 03 sits lower than my 00 did even though same truck and package. i would go wiht the leveling kit either way, makes the truck look perfect.
Old Apr 7, 2009 | 08:02 AM
DIHLON's Avatar
You can't put 16" wheels on an '08. They won't clear the brake calipers. 17" is the smallest you can go.
Old Apr 8, 2009 | 03:40 PM
thanks u may have just saved me a hell of a problem
Old Apr 8, 2009 | 04:45 PM
KR-Texas's Avatar
The most common wheel size you will see is 18x9 or 20x9 with 33x12.5 tires for a leveled truck in the 2004-2008 year range. A good backspace for the 9" wide wheel is anywhere between 5 and 6 inches. The smaller the backspace, the further they will stick out from under the truck.
The 18s are cheaper than 20s and I think our trucks look better with more tire, but some will disagree. There are a few who run 22s and several who run 17s, but the tire and wheel choices are more limited in these sizes.
Here is one of my favorite looks on a leveled 04-08 truck. The wheels are 20x9 XD Monsters with 5.71" of backspace and 33x12.5 Toyo MTs. Rimzone.com has the package for about $2475 shipped to your door. If you go with the same tire and wheel package in an 18" size, the cost drops to $2075.
KR-Texas
