35's advice
Old Mar 3, 2009 | 01:26 AM
btd25's Avatar
35's advice
I have an 04 F-150 with a 2.5AS leveling kit. Im going to run 35 toyo MTs but I want plenty of clearance and if possible a bit of lift. Suspension is out of the budget and I dont want to do body. Suggestions are much appreciated, especially with pics! Thanks in advance!!
Old Mar 3, 2009 | 03:48 AM
Hash278's Avatar
Hmmm the only was I can think of to lift our trucks would either be a leveling kit, bilstein adjustable shock although those are pointless since you already have a leveling kit, body lift and suspension lift. So those are really your only options
Old Mar 3, 2009 | 07:45 AM
yetti96's Avatar
I have to agree, unless you get rid of the leveling kit for a suspension lift, or get a body lift there is no other way to get more life. The true ground clearance will come from the bigger tires. Not quite sure what you really want. The 35s should fit with the leveling kit.
Old Mar 3, 2009 | 07:48 AM
BLACKOUT FX4's Avatar
x3
the tires should fit no problem with the 2.5 leveling kit
Old Mar 3, 2009 | 08:35 PM
XLT_STRONG's Avatar
They will fit no problem. I also have a 2.5 AS kit and I got 315/70/17 Firestone destination M/T's. I have no problem what so ever.
