Weak stopping power lifted Screw help????
I put new pad and rotors on my 01 Screw bled the system and the brakes seem weak. I let them break in for the first 150 miles and now I had to stop suddenly on the freeway and the pedal feels ok but if I push it as hard as I can it will not lockup or hit ABS? It just does not stop good at all and I put some good pads on from kragen. I had a expedition that had the same setup lift ect... and it stopped 10x better.
All I can think is it might be the master cylinder because thats all that is left and the truck has 150k on it? Never had one wear out so any help you guys could give me would be great!
And yes I know how to bleed brakes...
Thanks Dave!
Thanks Dave!
Same thing if you have a brake line leaking... the pedal would go to the floor.
It sounds to me like it has to be your pads or your rotors. Maybe your pads are glazed??? Try roughing them up with some sandpaper.
