who has installed the 2" AS leveling kit at home?
Old Feb 22, 2009 | 08:29 PM
deerhunter5639's Avatar
and how did it go? what tools did you need? how long did it take? any info is appreciated!
Old Feb 22, 2009 | 10:24 PM
has NO ONE installed the kit on their own?? come onnnnnn haha help me out guys
Old Feb 22, 2009 | 10:31 PM
wingman4's Avatar
Here ya go man:
https://www.f150online.com/forums/su...t-install.html
Old Feb 22, 2009 | 11:09 PM
FF/PM_L1563's Avatar
Doing mine on thursday. 2.5" NCD kit.
Old Feb 22, 2009 | 11:18 PM
TN-F150's Avatar
Did mine and common hand tools will be all you need. Piece of cake...
Old Feb 22, 2009 | 11:45 PM
Originally Posted by wingman4
thanks so much! now i'm ready to put this sucker on
Old Feb 22, 2009 | 11:51 PM
italiano's Avatar
i did mine at home as well just get an alignment when you are done.it wasnt too bad now that bottom bolt for the coilover is tight other than that easy install if you are good with tools.
Old Feb 23, 2009 | 06:30 AM
tomonjello's Avatar
I did the 2.5 AS at home. I do have air tools but hand tools are fine. Take your time. You will need a good 2 1/2 ton floor jack and some jack stands. Pick up some liquid wrench to make it go a little smoother.
Old Feb 23, 2009 | 07:39 PM
wingman4's Avatar
yup, no problem
Old Feb 24, 2009 | 03:37 AM
lObOdiablO's Avatar
i will if i only can get the kit here!
hard to get it in cancun
Old Feb 26, 2009 | 12:27 AM
hill2107's Avatar
did my 2.5AS myself. Wasnt to bad. If I did it again, i would rent a spring compressor and knock off about an hour or two of time.
Old Feb 26, 2009 | 12:46 AM
acruzomatic's Avatar
I did it myself here at home. Only help was from my 6 year old son. If I can do it so can you. Simple hand tools, jack stands, floor jack, pitman arm puller. All the tools needed are listed in the write up above. Print it out and follow it exactly. Just make sure you have all the tools before you get started. Don't ask me how I know that.
You're in Beaumont? Too bad you're not here in San Antonio, I would offer to help you out.
Old Feb 26, 2009 | 10:13 AM
rpxr400's Avatar
I also did mine at home. As others have said - it's an easy job if you have the tools.
I would just note that you don't need the pitman arm puller if you don't have it. I bought one and it wouldn't fit, so I just used a BFH (Big f@%# Hammer) to free it up and returned the puller. I probably smacked it a half dozen times and it freed up.
It's only a couple hour job. Nothing complicated about it.
Old Feb 26, 2009 | 05:46 PM
just did my ncd kit today. i highly reccommend getting this product. simple to put on and only required regular tools. no specialty tools required.
Old Feb 26, 2009 | 08:51 PM
ZSK's Avatar
ZSK
Another one here that did it myself, 2.5". I did it with basic hand tools and without removing the lower bolt for the shock.
