Will it fit
You can fit a 35x12.50 tire by using the oem wheels and a leveling kit. You can also use a wheel with almost identical specs. For instance, Paw Paw is running that size by using an 8 inch wide wheel with 5.5 inches of backspacing. THe oem wheels are 7.5 inches wide with 5.5 inches of bs. He tried using a 9 inch wide wheel and had serious rubbing.
thanks for the input i've done got the rims ordered so i guess trial and error will tell. If they don't work then i guess we will see how well there " No Hassle Return" system is lol
