Help help help! Abs question!
Old Feb 12, 2009 | 04:27 PM
cadkins09's Avatar
Exclamation Help help help! Abs question!
Ok so i still dont have an answer im replacing my rotors pretty soon and i dont know if i have 2 wheel or 4 wheel abs. help!!! i have 4 rotors (no drums) if that helps.
Old Feb 18, 2009 | 11:06 AM
crazyboy135's Avatar
To find out if you have 2 wheel or 4 wheel abs, try to find the sensor like the one in the picture on your rear axle. If you have one then you have 4 wheel abs.
-crazyboy135
Old Feb 18, 2009 | 11:59 AM
mkosu04's Avatar
There is an easier way...
open your hood
trace the lines out of the master cylinder
do they both go into the ABS module? If so, you have 4 wheel ABS.
If only one of them goes into the ABS module, you only have 2 wheel ABS.
Old Feb 18, 2009 | 01:25 PM
Geez! I forgot all about the easy way of doing it!
Old Feb 18, 2009 | 04:29 PM
cadkins09's Avatar
open your hood
thanks! i will be under the hood today putting in a new HID kit. i will check. some is actually being nice to me on here. unlike the jerks in the detail area when ive been detailing cars for the past 3 years.
Old Feb 19, 2009 | 11:45 AM
mkosu04's Avatar
ya... those detailing guys are a snobby bunch... stick to the other areas!
