Raybestos Advanced Technology brakes
Old Feb 10, 2009 | 09:53 AM
jtarms45's Avatar
Has anyone had any experience with the Raybestos Advanced Technology (Coated, drilled and slotted) rotors and pads? I'm looking to replace the brakes on my '08 SCrew Lariat soon. I can't find much for "upgraded" brakes for anything newer than an '07. I don't know if the manufacturers havn't updated their web site and catalogues or if there is even a difference in the '08 brakes compared to the '07s either.
Old Mar 4, 2009 | 11:57 AM
jtarms45's Avatar
What the hell...? NO ONE has use the Raybestos rotors or pads?
Old Mar 4, 2009 | 11:59 AM
I have the standard Raybestos rotors, not drilled and coated. Also, I have Wagner ThermoQuiet pads. Will be time for some more pretty soon, have 71,000 on them.
Old Mar 4, 2009 | 08:01 PM
beechkid's Avatar
25 Year Member
I do not trust raybestos products in any shape or form- I have experienced new drums shattering (less than 50 miles), brake pads fracture and multiple calls (from myself, machine shop and retailer) left un-returned from Raybestos.
Recommendation: CarboTech Engineering lining, which I have used for about 15+ years and been very happy on multiple full size (V8) cars and trucks. This particular lining has a high friction co-efficient, excellent pedal feel, wear (typically 50,000 to 75,000 miles before replacement is required) and produces less dust than OEM linings. IIRR, I paid about $130 for my last set including shipping. They have a web site at www.ctbrakes.com, but I highly recommend speaking to them by phone for linings that would be best for your application at 877-899-5024 or 704-481-8500. With regards to rotors, I run Brembo OEM replacement rotors that are cryogenically treated making them almost as hard as stainless steel. For street use, slotted/drilled rotors are just “cheese-graters” for the brake pads IMHO, because unless you are involved in true racing conditions, the brake linings do not produce the gases which slotted/drilled rotors are designed to relive. In some cases, brake testing indicated reduce brake efficiency in street-based operations using slotted/drilled rotors when equal comparisons were made. The staff at carbo can speak to you as well regarding those options, but I am very satisfied with the performance & wear of these products.
Old Mar 5, 2009 | 08:55 AM
BLUE20004X4's Avatar
Never used Raybestos rotors, just pads- Carquest branded pads are mostly Raybestos mfgr'd. Never a problem. I wouldn't myself get cross drilled rotors for a truck anyways.
Old Mar 6, 2009 | 01:55 PM
F150FXOnline's Avatar
opps sorry
