How big can I go?
Old Jan 17, 2009 | 11:01 AM
dclydep's Avatar
How big can I go?
I am trying to find out how much tire my 2003 F150 SuperCrew Larait FX4 can handle without any modifications to the suspension or body lift.
Thanks for your help.
Old Jan 17, 2009 | 11:25 AM
A 285x70x17 which is close to 33 inches tall will fit on the stock 17" wheel's, guessing that's what's on your truck.
Old Jan 17, 2009 | 11:38 AM
nateinoc's Avatar
I have 18" rims what would be the biggest without rubbing or any problems,with a 2.5 leveling kit?
Old Jan 17, 2009 | 11:50 AM
95'F-150's Avatar
Probably like a 305. I've got 35's on with a 3in Body Lift and had to trim very slightly on the lower skirt, but you can't really even tell that its been trimmed. With a 2.5 leveling kit you may be able to fit a 305.
Old Jan 17, 2009 | 12:05 PM
If you have a 2005 4x4 leveled you can fit a 305x65x18 easily. a 35x12.5 will fit but you may have some rubbing on the control arm's. This is based on a stock Ford 18" wheel.
Old Jan 17, 2009 | 02:04 PM
4wd150's Avatar
correct.
and to the OP, assuming you have 17" wheels a 285/70/17 would look great. also if you wanted something a little wider you could consider a 305/65/17
Old Jan 17, 2009 | 03:36 PM
dclydep's Avatar
I appreciate everyones reply
Old Jan 17, 2009 | 04:30 PM
chiefFX4's Avatar
i had a 305/70r16 on mine before the suspension lift. aftermarket rims though.
Old Jan 21, 2009 | 12:53 AM
tomlunati's Avatar
Im new here and im just wondering what the biggest tires i can run on the stock highboy suspension is.....? It has 265-75-16's on it right now. Its a 77 with the stock suspension, 4x4, 460 engine with 4 speed tranny.
Old Jan 21, 2009 | 01:48 PM
wandell's Avatar
Welcome to the site. You will get more responses if you start a new thread with your question rather than digging up aging threads.
