what psi for 305/55/20?
Old Dec 13, 2008 | 07:38 PM
bewtew's Avatar
the tech inflated it to 60 upon mounting. he suggested 60 when cold 65 when hot. recommendations? thanks!
Old Dec 13, 2008 | 08:13 PM
kingfish51's Avatar
What is the load rating and max psi cold. Can't give you any information without that info.
Old Dec 13, 2008 | 10:08 PM
wandell's Avatar
I've always had good luck with 40 psi for daily driving.
Old Dec 14, 2008 | 02:21 PM
bewtew's Avatar
tire is nitto terra grappler, load range E, max load at 3195lbs with max psi @ 65 (cold). truck is used mainly as DD. hope this helps.
Old Dec 14, 2008 | 03:12 PM
kingfish51's Avatar
Those I would run at 45. If you decide to go lower, don't go lower than 40 and if you do any towing or carrying of loads, bump it up. 45 should be good enough for just about anything.
Old Dec 15, 2008 | 02:46 AM
bewtew's Avatar
just out of curiosity, why around 40-45 psi when max states 65. being the newb i am, id consider 60 cuz it seems more reasonable/logical to me. id think anything lower than 60 is considered underflated and would cause uneven wear. could you guys explain how you guys come up with the numbers? please dont get me wrong. i took wandell's advice before and my old tires wore perfectly and had even traction.
Old Dec 15, 2008 | 07:40 AM
kingfish51's Avatar
Your tire is rated at 3195 at 65psi. Your truck is rated at less than 4k per axle, or less than 2k per tire. 45 should give you the ability to carry that 2k+ and not wear the center of the tread due to over-inflation. At 60, your tire will basically be sitting on just the center section of the tread, especially when unloaded.
To give another example, on my truck, I use load range C tires that handle around 2400lbs per tire at 50 psi. I use 40 to get the proper inflation for the vehicle. If I used 50, all i would do is give it an extra harsh ride, have less tread on the pavement, which will cause problems, especially in wet, and wear the tire too quick.
Old Dec 16, 2008 | 12:15 AM
bewtew's Avatar
thanks it makes more sense now!
Old Dec 16, 2008 | 04:12 PM
kingfish51's Avatar
I should have mentioned before. It is ALWAYS better to over inflate (up to the tire max pressure) than under inflate. Over will cause excessive tire wear in the center of the tread. Under will cause excessive wear on the 2 sides of the tread and may cause over heating of the tire at highway speeds, causing possible blowouts and tread separation.
