Will 17" **** Cepek DC-1 wheels with 33x12.50's fit on 2008 FX4?
Old Dec 9, 2008 | 09:22 AM
obe80's Avatar
I am brand new, this is my first post on here!
First off, I have a 2008 F150 FX4. I will be adding a 2.5" leveling kit, and I am looking to get a set of 17" DC-1 wheels and not sure yet on the tires, but I want 33X12.50's. Does anyone have this setup on an newer FX4?? I was wondering if this will fit. Any pics or help would be greatly appreciated! Thanks!
Old Dec 9, 2008 | 09:41 AM
05_sprcrw's Avatar
I thought I have read something about our trucks brake calipers having issues clearing inside 17" wheels. I think you can only fir 18+ wheels on our trucks. (I am probably wrong but just passing what I know along)
Old Dec 9, 2008 | 10:03 AM
06yz250f's Avatar
i have 17's.....
some have 17's from the factory.
Old Dec 9, 2008 | 10:18 AM
05_sprcrw's Avatar
Originally Posted by 06yz250f
i have 17's.....
See I told you I was probably going to be wrong! Thanks for setting it straight, but I still think I read something about some aftermarket 17's not clearing the calipers. (I just don't want to say they will fit and then them not fit for him)
Old Dec 9, 2008 | 11:00 AM
06yz250f's Avatar
ya i think i heard that a while back, but i have 17's w/ no problems, chaz has 17's with no problems, i think thor has some as well. thats just off the top of my head, but i haven't heard a thread lately about someones 17 not fitting, so chances are no problems. just have the place you buy them from test fit them first to make sure everything clears.
Old Dec 9, 2008 | 12:32 PM
obe80's Avatar
Thanks guys! I currently have the stock 18's right now. If those 17" DC-1's do fit, and I run a 33X12.50-17 tire is there any chance of rubbing at full crank?? Will going to a 33" affect my speedometer?
Old Dec 9, 2008 | 12:38 PM
06yz250f's Avatar
2wd or 4wd?
2wd you will need a 2 1/2" leveling kit, and depending on wheel spec yes or no
4wd with no 2 1/2= maybe probly not
with 2 1/2= i really doubt it, you can fit a 35 on stock rims w/ a leveling kit
wandell will be able to let you know for sure tho
Old Dec 9, 2008 | 01:21 PM
In '05 they had some problems with aftermarket wheels clearing the calipers, I was able to clear my '04's brakes with no problems with my 17" wheels (both sets). A leveled 4x4 can clear up to a 35x12.5 tire with the stock wheels or aftermarket wheels with close to stock specs.
Old Dec 9, 2008 | 02:35 PM
obe80's Avatar
2wd or 4wd?
Its 4WD.
I was looking at a 2.5" leveling kit.
Old Dec 9, 2008 | 03:10 PM
06yz250f's Avatar
Its 4WD.
yea, you should be fine then would be my guess. whats the wheel specs? if your getting a leveling kit, i really really doubt there would be any rubbing.
like paw paw said, you can fit a 35 with stock rims so i really can't see 33's being a problem.
Old Dec 9, 2008 | 04:46 PM
obe80's Avatar
They are 17x9 with 4.53" backspacing and -12mm offset.
Do you think they will stick out??
Old Dec 9, 2008 | 05:26 PM
06yz250f's Avatar
to compare my wheel specs are 17x9 with 4 5/8 backspacing and -8mm offset. my wheels stick out about 2 inches or so. gives it a good look but doesn't stick out to far.
i am by no means a wheel expert, i am just learning as i go.
Old Dec 9, 2008 | 05:58 PM
fx4 for life 79's Avatar
you will be fine with 17's, and if you stick with a 33" tire you should be fine might have to trim a little bit
Old Dec 9, 2008 | 06:16 PM
dkgreyf150's Avatar
mine are 17x9 dc1 polished 4.53 backspacing -12 offset with a 35x12.50R17 **** cepek mud country with a 6" full traction lift
Old Dec 9, 2008 | 08:26 PM
Those wheels will stick out 2 1/2 inches more than stock. I'd check out the 305x65x17 tires or the 295x70x17 tires. That's about the max on those wheels with a leveling kit to avoid rubbing. The more you stick out in the front wheelwells the more chances to rub with larger tires.
