Need some advice
Old Dec 7, 2008 | 10:23 PM
Trev18's Avatar
Need some advice
Ok so I have a totally stock 2005 f150 fx4. I want to do some work to it but I'm new to this so I don't really know where to start. I want to do exhaust, bull bar and some other stuff like that but my main concern is the wheels/tires. Whats the biggest tire I can go with without lifting the truck. I plan on a leveling kit but I wasn't going to lift it. If need be I will though. Any advice you guys may have or pictures to see what different setups look like would be greatly appreciated. Again I'm new to this forum so I apologize if this is in the wrong spot
Old Dec 7, 2008 | 10:39 PM
wandell's Avatar
I'd go with a 2 or 2.5 inch Autospring leveling kit. Your truck will look a lot better and you will be able to fit up to a 35x12.50 tire using the oem wheels or 33's using wider aftermarket wheels. Personally, I'd go with a set of 325/60-18 (33x13.00) all terrian tires on a 18x9 inch wheel with 5 to 6 inches of backspacing.
Old Dec 7, 2008 | 11:19 PM
Trev18's Avatar
Alright thanks for the help. I like the "beefy" look if that makes sense to anyone so a wider tire seems like the preferred route for me. Does anyone have any pictures of what this suggested setup may look like? Thanks again for the help!
