Rear Brake Question
Old Dec 5, 2008 | 09:33 PM
OneFastGSXR's Avatar
Rear Brake Question
Hey guys, I know this is an f150 but my Gas Saver's rear brakes are acting up and I know how knowledgable you guys are in general!!! Anyways, When I brake at slow speeds the rear end of the Cavalier drops down.. Also the ABS seems to be real touchy and goes off when not needed... Being the retard I am, I took it apart and had my GF hit the brakes when the drum was off so I could see if the springs were pulling back the Shoes when the pedal was released... Needless to say I think the seals are blown. Any Ideas on a solution???
Thanks a Bunch guys
Sean
Old Dec 7, 2008 | 07:08 PM
defconfive's Avatar
Registered User
What seals are you referring to? The cylinders?
It is entirely possible a cylinder or two has gone bad. I replaced all mine in September. Remember, you can't just place one. You must do it in pairs. $17 a piece at Carquest.
Old Dec 10, 2008 | 06:04 PM
beechkid's Avatar
25 Year Member
Not a big deal, just take a little emery cloth and clean up the inside of the wheel cylinders, clean with brake clean, towel dry, lube with brake fluid, re-assemble.
