Please help me with my 06 Lariat truck and tires
Old Dec 4, 2008 | 02:03 AM
jigrana's Avatar
I have done a lor of reading and still dont know what to do
Here is what I have.
2006 Lariat Crew 4x2 5.4L
Here is what I just bought.
TOYO Open Country M/T 35x12.50R20LT
on 20x10J Rims
Here is a larger Pic of the tire
http://www.thegranados.com/f150/tire.jpg
and tomorrow I'll post pics of the truck
What I need to know is can I put this tires with just a leveling kit.
Please I realy need help. I dont know what to do
Here is a Picture of the truck
Old Dec 4, 2008 | 02:48 AM
Lord Helmut's Avatar
just mount one on the front and test fit it. turn your wheel left and right and have someone watch for clearence issues if all seems good mount all of them and road test
Old Dec 4, 2008 | 02:57 AM
bewtew's Avatar
On a 4x2 i believe that the largest you can go with just a leveling kit is 33" tires. you need to be at 4x4 height to begin with to fit 35" w/ leveling kit. you might need a full suspension lift.
Old Dec 4, 2008 | 03:10 AM
th3godf4th3r's Avatar
im sure youll need a 2.5 AS leveling kit
Old Dec 4, 2008 | 03:32 AM
OP, first off, welcome to the site. Second, please don't cross post the same thread in multiple forums. Thanks!
Old Dec 4, 2008 | 06:58 AM
hivoltagefx4's Avatar
Well? Based on your truck being a 4x2 and not knowing the backspacing on your wheels? You will need a minimum of a 6" suspension lift to run 20x10 wheels on 35's. A leveling kit alone will not allow you to run this setup. Just a bit of info, always check the size and backspacing of the wheel you want to run before buying. Same goes for deciding what tire size you want. That will determine what you need to do to your truck in order to run them.
Old Dec 4, 2008 | 08:27 AM
DIHLON's Avatar
Or you could go with a body lift + level kit. The suspension lift would look better though.
Old Dec 4, 2008 | 10:39 AM
wandell's Avatar
I agree.
