Double check me
Old Nov 17, 2008 | 12:43 PM
Drdudsads
Guest
Posts: n/a
Double check me
Well I have 315/70/r17 BFG tires and finally found a set of rims I like for it. I dunno if they will fit on the truck though. I have the bilstien shocks on the way and fiberglass for clearences. So here are the rims will they fit on my truck?
http://aewheel.com/eagle_alloy_wheels.cfm?id=100
They are the Series 101B 17X9
Here are the specs.
17x9-size
Black 6 on 135mm-finish and pattern
-8 mm-offset
4 5/8-backspacing
2100 lbs.- load
Old Nov 17, 2008 | 12:58 PM
wandell's Avatar
Yes, those will fit. I take it you mean some type of prerunner styled fenders. You will need some extra clearance to fit 35's with only Bilstiens.
Old Nov 17, 2008 | 01:08 PM
Drdudsads
Guest
Posts: n/a
Sweet! Ordering em friday payday! Haha, Yes I do mean fiberglass fenders so I can have a larger wheel well opening. The bilstiens are to make the truck level and ride better hopefully. Doing the +2 up front and the +1 in the rear.
Old Nov 18, 2008 | 09:56 PM
http:// These are 315x70x17 BFG's on 17x9 wheels with 5 inches of backspacing. Had minor rubbing on lower wheelwells even with trimming. Glass fenders ought to do the trick.
