what offset can i use
Old Nov 4, 2008 | 07:37 PM
wernerslostblue's Avatar
1.5 leveling kit, pretty much stock.
i want 20" rims what offset do i get to make them stick out about a half inch. from the top of the fender or atleast flush with the top of the stock fender flare. stock rims are not flush they are sucked in a tad wich looks pretty wimpy.
Old Nov 4, 2008 | 10:44 PM
wandell's Avatar
If you are wanting an offroad style wheel, a 9 inch wide wheel with 5 inches of backspacing is pretty common. This means the wheel with stick out 2 inches farther than the oem 17 and 18 inch wheels.
Old Nov 5, 2008 | 02:02 AM
Fifty150's Avatar
I'm using a 9" wide wheel w/ 4.625" of backspacing.
Old Nov 5, 2008 | 09:50 AM
slug420's Avatar
where would a 20x8.5" wheel with +20mm offset fit in?
I am looking at a set and just want something with a stock fitment to run OEMish tires on for the winter....im not sure how 8.5" wide and +20mm offset translates into inches of backspacing.
