Installed Ballistic Jesters
Old Oct 15, 2008 | 03:02 PM
ColonelBlue's Avatar
not a bad looking wheel except the red and your color dont really go.but not bad as long as you like
Old Oct 15, 2008 | 08:49 PM
Hard2Believe's Avatar
Originally Posted by Blue150
Are these them?
Size: 18 x 9
Bolt Circle: 6x135 (5.31)
Offset: +12
Back space: 5.47
That's the correct size. I was rubbing on the driver side where the fender well meets the trim. If you are standing looking directly at the front driver side wheel, it is on the right side of the tire on the outside lip. Kinda hard to explain, I may have to post a picture.
Old Oct 16, 2008 | 08:18 AM
DIHLON's Avatar
I didn't think you could squeeze a 325/60/18 on a 2wd. You've just convinced me to go with a 305/60/18 now instead of the 285/65/18. I was worried about the 305 fitting but if you got the 325 to fit I should be fine.
