Need Pics of 33's on an FX4
Old Aug 25, 2008 | 10:19 AM
gp1200r2000's Avatar
Originally Posted by LegIron
Thanks for all of the comments on the truck, now to answer a few questions.
I installed a 2" Auto Spring leveling kit and 3" blocks in the rear.
The wheels are stock and I mounted the BFG KM2 mud terrians on them.
My cap is made by Century and it is there "Royal" model which gives the SUV type look.
I'm running stock 3:73 gears with the 5.4 motor. Exhaust is by Flow Master and the tuner is an XCal2.
Hope this helps and if you have any other questions let me know.
Thanks for the help 1 question the 3inch block in the rear what is that for? Could i just do the front leveing kit and the same tires that you have and will it work,I have the same rims.Thanks again Craig
Old Aug 25, 2008 | 01:13 PM
LegIron's Avatar
Sometimes the front sits a little higher than the back after a leveling kit is installed but mine was real good before I add the cap. Once I add the cap the back sat slightly lower than the front and I added the 3" blocks to help even things out. If you are running with an open box, no cap, you should be fine.
Glad to have helped.
Old Aug 25, 2008 | 01:25 PM
LegIron's Avatar
Originally Posted by SASKFORD
I see that both of you guys have levelling kits. Here is my next question...will I require one? I already have 32" tires on the truck but the extra width is what concerns me. Any thoughts?
Most guys do run a 2 1/2" leveling kit with 33's or 35's on the 2004 trucks. With yours being an FX4 you might get by without it but a leveling kit would make the tires fit with no problems.
Old Aug 25, 2008 | 04:08 PM
Jaderbutt's Avatar
That is the same size and style of tire I am looking to purchase. Just need to save up the pennies! Love the cap by the way
