Would These Wheels Work??
Old Jul 31, 2008 | 02:05 PM
rtoycrow's Avatar
I am new to all of this so bare with me. I want to get these wheels in 18"
http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123
i asked and the 8.5 is as wide as they come. I know nothing about this but i want to run them with toyo open country 35's. Would these wheels work with those tires . I have a 06 4wd lariat with a 3 inch leveling kit (i know, i should have gone with a 2.5 but i found out about it after it was already installed) any suggestions would be appreciated. I would like for the wheels to stick out just a little bit. Thanks
Old Jul 31, 2008 | 09:17 PM
wandell's Avatar
I'm not sure what that offset works out to be in backspacing, but you won't be able to fit 35's with those unless you lift your truck more.
Old Aug 1, 2008 | 08:22 AM
franknardels's Avatar
limo hire
The wheel is a very simple machine, even if the concept could
have been accidentally reached the concepts of tools and their use,limo hire
Old Aug 1, 2008 | 09:19 AM
rtoycrow's Avatar
I really don't understand. What would i need to do to get 35's with a 3 leveling kit to fit? Does the rim have to be a certain size? I was told i could fit 35's on there with just the leveling kit by itself. I have factory 20's on there now but i want something different.
Old Aug 1, 2008 | 10:20 AM
fly11269's Avatar
here is the calculator....
http://www.autolounge.net/calculators/tirespacing.html
fly
Old Aug 1, 2008 | 12:48 PM
wandell's Avatar
TO fit 35's on a stock 4x4, with only a leveling kit you have to use the oem wheels or one with almost identical specs. PawPaw fit 35x12.50's using an 8 inch wide wheel with 5.5 inches of bs. The oem wheels are 7.5 inches wide with 5.5 inches of bs.
