bfg km2 vs toyo open contry mt
I think the sidewall of the toyo looks better but i know that they are less capable in the dirt. The KM2 is a beast offroad, easily one of the best aggressive radial tires ever made! Cant go wrong with either though since they are both good tire manufacturers.
...KM2's because you don't see them on every other lifted truck you look at.
the only reason i dislike the km2's is because they do not look wide enough i would like a wider tire...
any suggestion of other mt's
keep in mind i also selected these because i do 99% highway
i think the toyo's might be a little wider than most other tires. like i know in a 315/75r16, the toyo m/t is about a 35x13.00, while most others are about a 35x12.50. keep in mind how wide your tires look will also depend on the width of your rims though too
You'd be happy with either tire but with 99% highway driving I'd stick with toyo's and call it a day
i thought the treadlife was about the same on both
