Need some input
BFG At 305/65R18
I have a '06 F-150 FX4 with 3.73 gears. I am planning on installing BFG AT 305/65R18 on my stock rims when my Rugged Trails finish wearin out. I already have 2.5" leveling kit on it. I know the speed will be off about 3 mph but what about the odometer? How much will the shift points be off? Is a programmer necessary for this setup? I know lots of people are running this setup and it looks really good if yall could help me out.
Is it necessary to put in a programmer with 1.8" difference? Any idea how bad off the shift points are?
no, but it may shift a little odd. the only way to really correct this is by regearing. it shouldn't be that serious w/ such a modest increase in tire size. the odometer will be off in your favor, ie reading LESS miles than it actually should display.
I have found i need 3.94 to regain performance, for yall who has this setup does it sound right? How much is it to regear? i'd prolly do it myself so does anyone know just the price of gears? And does it correct the speedometer/odometer?
I have read others threads and some say a dealer can recalibrate the computer to a different size as long it is a optional tire size for the truck and others say it can be any size..so which is it?
It is a percentage. Both speedo and odo will be inaccuate by the same percentage. If you increase tire size, then you will actually be running faster than your speedo reads and less milage will be recorded on your odo. With Wandell he was experiencing close to a 10% difference, so the odo would be off by the same.
