Largest Tire
Old Jul 21, 2008 | 09:23 AM
statgator's Avatar
Largest Tire
Hey guys,
I have a 2005 F150 extended Cab FX4. The factory tires are 255 70R17. I need new tires.
What is the largest tire I can use without getting any rubbing? I don't want to change the rim so this is just for the tire.
I prefer the look of wider tires. Are there downsides to a wider tire? Should I just stick with the stock tire?
Tom
Old Jul 21, 2008 | 09:44 AM
minimonster17's Avatar
if your truck is a 4WD, with a leveling kit, you could fit a 35x12.50x17
Old Jul 21, 2008 | 12:40 PM
wandell's Avatar
RIght. YOu could also run 285/70-17's (33x11.50), 295/70-17's (34x12.00) or 305/65-17's (33x12.50) with our without a leveling kit.
Old Jul 21, 2008 | 04:41 PM
statgator's Avatar
My truck is completely stock.
So are you telling me that I could run a
255/70/17
265/70/17
275/70/17
or
285/70/17
Is there an advantage to staying at the 255?
Tom
Old Jul 21, 2008 | 04:47 PM
MercedesTech's Avatar
gas mileage would be your only advantage with the smaller tire. Less rolling resitance and less unsprung weight = better MPG's .
Old Jul 22, 2008 | 08:31 AM
statgator's Avatar
Thanks for the info.
I'm surprised I run a tire so much larger than the stock tire.
Tom
