Brake line replacement & ABS Light On
Old Jul 15, 2008 | 09:33 PM
mig25's Avatar
My truck has ABS light steady on and also the Brake light on.
I run a wire under the air filter and under I believe is the ABS module and since then the light came on, I was installing an alarm, and Just ran the cable did not connect it to anything.
Is the Module that round thing between the air filter and relay box?
Also I will need to replace my front lines ( Flex Lines ) it is all rusted out and it seems to be leaking.
I am concerned about bending the new line.
Any suggestions ?
1997 F150 V8 4.6 4x4 Auto
Old Jul 16, 2008 | 11:34 PM
bxstang2000's Avatar
If any part of the braking system is leaking you should replace it. Check the fluid in the master cylinder if the fluid is low or the float is stuck the ABS and BRAKE light will come on.
