Little Help?
Old Jul 2, 2008 | 04:30 PM
Mudbug05's Avatar
Little Help?
I'm runnin around in a 05 150 Lariat Scab, 2wd with a 5.4L and need new tires. I will probably stay with BFGs and b/c I am not in the position to purchase new rims, will be staying with my stock 18"s.
I put on some Bilstein leveling shocks (2") on and want the biggest tire I can fit under there with little to no rubbing. I would like to stay with the AT style due to being off road some. What is the biggest size I can put on these factory rims given my specs? I am not real good with the tire company measurements either so a translation would be helpful.
Old Jul 2, 2008 | 09:17 PM
wandell's Avatar
If you are gonna use the oem wheels you could squeeze a 305/65-18 (34x12.50) AT KO on your truck with the Bilstien shocks. You could also use the slightly smaller 285/65-18 (33x11.50) AT KO.
Old Jul 2, 2008 | 09:39 PM
keith_bennett's Avatar
I would say some 33's(285/65).
Old Jul 3, 2008 | 10:02 AM
Mudbug05's Avatar
Thanks Wandell. I was hoping to at least get some 34"s under there. I want to fill the wheel well a little more. I am currently running BFG G-Force KOW's (285/60/18). I think they are entirely to flatlander and small.
I assume the BFG AT KOs (34X12.5) will increase my tire height and width by an inch either way. I like the tread on these. Many of my friends have them and I just wanted to know if they would work for a leveled 2wd. They all have 4wd.
Old Jul 3, 2008 | 12:13 PM
wandell's Avatar
Yeah, the 4x4's sit about 2 inches taller than the 4x2's. You will probably have some minor rubbing with the 305/65-18's but it should be minor.
Old Jul 3, 2008 | 01:01 PM
Mudbug05's Avatar
Thanks Buddy. I'll watch the full lockin when turning. Gonna be hard when I need to do a U-turn.
Old Jul 3, 2008 | 01:31 PM
Mudbug05's Avatar
One more bro. Do you suppose when switching from a 285 to a 305, there would be a problem with Odometer or MPH calculations or is that not such a significant switch. I imagine it would only be crucial to re-calibrate only if I went with a larger rim and lets say a 35. Sound right?
Old Jul 3, 2008 | 01:52 PM
4.2trimble's Avatar
your speedo and odometer will be slightly off but not enough spend the money to mess with it
Old Jul 3, 2008 | 06:46 PM
Mudbug05's Avatar
Thanks Trimble, I was hopin it wouldn't be nothin.
