Wheel size?
Old Jun 26, 2008 | 02:05 PM
Mach-1's Avatar
Question Wheel size?
SIZE........OFFSET.......BACKSPACE.......TIRE
17x9........-12............4.53".......33x12.5OR17 Discoverer ST
I have a AS 2" level kit on the front. The tire man said there might be an issue with rubbing on the truck because of the -12 offset.
So my ? is does anybody have these rims with the same or similar setup as mine and is there any rubbing?
05 FX4.
Thanks for the help.
Old Jun 26, 2008 | 06:17 PM
They will stick out about 2 1/2 inches more than stock and if you limit to a 33 inch tire you ought to be OK. If your truck is leveled in the front it will also give more clearance.
Old Jun 26, 2008 | 08:40 PM
wandell's Avatar
I agree. If you have any rubbing it will be pretty minor. I think you will be fine.
