What's the min. lift
Old Jun 23, 2008 | 11:50 AM
TRUEBLUE2004's Avatar
I have a 2004 F-150 Screw FX4 (nbs). I would like to run these rims in 18X9 Chrome 6 on 135mm -11 mm 4.50 3226-06 2100 lbs. 35 lbs. This is the only size they have in this style w/ 6 on 135mm thats an 18. I would like to run 325 or 305 **** cepeck radial fun country tires of bfg a/t. How much lift would I need to run this. I would like to only run a leveling kit w/ maybe a small block in the back but I don't want any rubbing issues at full suspension travel. Thanks for your help. BTW this is the wheel. http://aewheel.com/eagle_alloy_wheels.cfm?id=363
Old Jun 23, 2008 | 08:39 PM
wandell's Avatar
You can run a 325/60-18 (33x13.00) with a 2.5 inch leveling kit.
Old Jun 24, 2008 | 12:47 PM
even with these rims
Just checking b/f I spend a couple thousand dollars.
Old Jun 24, 2008 | 12:50 PM
wandell's Avatar
Yeah, you may have to do a little trimming because of the backspacing on the wheels but 325/60-18's will fit. Most 18x9's have 5 inches of bs, so it's a more common setup.
