20" Mud Tire.
Old Jun 22, 2008 | 11:57 PM
brian2k's Avatar
20" Mud Tire.
Guys I can't find a mud tire for anything to fit my stock 20" wheels on my 08 FX4. I know there gotta be something out their right? If so where? The only thing I have found close is a BFG All-Terrain and they want like $415 per tire. Thanks for any info ya'll may have!!
Old Jun 23, 2008 | 12:10 AM
4.2trimble's Avatar
look at Nitto, Cooper STT, Mickey Thompson MTZ, Super Samper Irok, possibly Kumho
Old Jun 23, 2008 | 09:19 AM
wandell's Avatar
I agree.
Old Jun 23, 2008 | 10:44 AM
FoMoCoFan17's Avatar
BFG makes the KM2 in 33" and 35" for a 20" rim.
Link----> http://www.bfgoodrichtires.com/specs...-km2/3930.html
Old Jun 23, 2008 | 10:54 AM
4X4AUTIGER's Avatar
Toyo Open Country M/ts all the way
Old Jun 23, 2008 | 01:10 PM
brian2k's Avatar
ok great, thanx for all the help guys!
Old Jun 23, 2008 | 10:53 PM
jfm_chuy's Avatar
Hay Brian im stuck on the same boat. I just dont know what to go with Nitto or Toyo.Heck i need a good set to last cuz i put alot of miles on my truck,and what size to go with. Do you have a size in mind?
Old Jun 23, 2008 | 10:57 PM
brian2k's Avatar
Yea I wanted to go with a 35/20. I was checking out some tires in this size and personally I like the Nitto's better then I do the Toyo's. Reason being is that the Toyo's are a little to wide for my taste!
Old Jun 23, 2008 | 11:15 PM
jfm_chuy's Avatar
Do you a have a lift at all on your truck? See and what gets me a guy from big o tires said that a 35 would be to big but i put a Leveling kit on my truck.
Old Jun 23, 2008 | 11:49 PM
brian2k's Avatar
I do not have a lift right now. But have plans on a 6" ProComp Suspension lift and a Skyjacker 3" body lift in the near future. If your truck is at stock height, you will definitely need a lift in order to run 35" tires. With that being said I would not run a bigger tire then a 35" unless you plan on changing out your gears.
Old Jun 24, 2008 | 12:33 PM
wandell's Avatar
You can fit 35x12.50's on a 4x4 with a leveling kit if you use the oem wheels.
Old Jun 24, 2008 | 12:41 PM
miseroth's Avatar
MY 2007 Screw 4x4 is going to need new tires soon (replacing the Pirelli Scorpion tires). Keep us posted as to what you find including the price, as I was planning on installing the level kit and going with 35" tires, but they are definitely not cheap...just about twice the price per tire compared to the 35" Goodyear MT/Rs that I have on my 1991 Bronco (in the 15" size)!!
Old Jun 24, 2008 | 01:45 PM
Live2Hunt's Avatar
Its not a mud tire, but I chose it for the same reasons you have.
http://www.coopertire.com/html/produ...?page=zeon_ltz
Old Jun 24, 2008 | 08:55 PM
jfm_chuy's Avatar
Ya i guess i better stay away from 35s then if i have to change gears and stock rims O well. Well im pretty sure ill make up my mind some time this month about getiing tires but when i do ill post pics.
Old Jun 26, 2008 | 06:50 PM
ian51279's Avatar
You don't have to change gears or wheels to run 35's.
