Tire Size Issue
Old Jun 17, 2008 | 03:28 PM
vtwingod's Avatar
Tire Size Issue
I was about to buy Nitto Terra Grapplers from Discount Tire and they said the biggest I could go without the tread crowning and wearing in the center is a 285/70/17. I was planning on buying either 295/70/17 or 305/70/17. I have a 2005 4x4 screw w/a 3" body lift. Will I not get enough life out of 295's or 305's with OEM wheels? I don't want to spend $700 or $800 on tires to have them wear incorrectly.
Old Jun 17, 2008 | 08:45 PM
wandell's Avatar
Any time you mount a tire on a narrower than recommended wheel it can cause the center portion of the tread to wear slightly faster than normal. Most tire manufacturers do recommend at least a 8 inch wide wheel for 295 to 315mm wide tires. However, several members here and FTW have run 315mm wide tires on the oem 7.5 inch wide wheels with no problems.
Old Jun 20, 2008 | 06:24 AM
vtwingod's Avatar
Wheel Size Issue
Will these wheels work with the 295/70/17 Nitto Terra Grapplers (which I received yesterday) and my '05 4x4 screw w/3" body lift? I'm a little nervous about using the OE wheels.
American Racing ATX Predators
Offset: 15
Backside: 5.375
6x135
http://www.americanracing.com/browse_atx.asp
Thanks,
Rick
Old Jun 20, 2008 | 02:09 PM
wandell's Avatar
Yeah, those should fit fine.
