Brake Line Size?
Old Jun 17, 2008 | 04:46 AM
hootdangmac's Avatar
Brake Line Size?
Hello,
I have a 98 F-150 2wd four six.
I am needing to replace the steel brake line from front to back. I know I can use my old fittings, but, need to know the size line to order. Does anyone know that right off? I am going to order a roll from jcwhitney.
Also I ordered this flaring kit http://www.sears.com/shc/s/p_10153_1...52000&sLevel=0
This kit will do any flaring I need for the job right?
Thanks for your help in advance!
Old Jun 17, 2008 | 05:34 PM
Anyone???
Old Jun 18, 2008 | 05:32 PM
keith97xlt's Avatar
its 3/16 you can buy preflared lines at autozone or advanced. you dont even need that sears kit. dont use the old fittings. all u need is the tubing bender.
Old Jun 18, 2008 | 10:27 PM
krazyballer's Avatar
Yes that flare kit will work.
Old Jun 19, 2008 | 05:28 AM
Thanks for your help guys. Unfortunately, I am not in an area with an autozone or an advance. I have to order everything online. They only offer 1 kit to replace lines on my truck, and, it is over 150$.
Jcwhitney has a great deal on replacement lines and sell them in a roll of 25'. So, I will go that route.
Thanks again.
Old Jun 19, 2008 | 10:57 AM
tech-doc's Avatar
You can reuse the old fittings, if, they are not rusted. Something to think about when ordering your lines.
Old Jun 2, 2009 | 11:06 PM
LFSracing's Avatar
what is the size of the fittings that screw in for the lines? I need some lines for my 97 F150 but they wanted to know size of the line and size of the thread for the fitting when I went to the part store.
Then I will go ahead and get a rough guestimate for the length I need both lines on the rear end are rusted bad.
Lorenzo
