check this outtt..37x12.50
Old May 30, 2008 | 10:47 AM
  #31
fx4 for life 79's Avatar
i just couldnt see fitting a 35 on my truck without rubbing let alone a 37
Old May 30, 2008 | 12:19 PM
  #32
wandell's Avatar
You might want to suggest he lower the tire pressure. Running too much air in a wide tire on a narrow wheel is gonna make the center of the tire's tread wear faster. I'd suggest 35 to 40 psi for daily driving.
Old May 30, 2008 | 12:31 PM
  #33
neuspeed5's Avatar
Originally Posted by madmaxwell87
so if they fit why are guys puting on 8" rize lifts to clear 37's? aftermarket wheels? i think it looks awesome
Because, to some of us, it looks better to have the lift.
Old May 30, 2008 | 12:42 PM
  #34
MercedesTech's Avatar
Originally Posted by ATOM
why? 37's and stock rims, i wouldnt try railing any corners with that setup. that truck could roll so easy being up that high and rims that narrow. i cant see how those dont rub, 35's will rub the upper control arms, let alone 37's?? 07 and 08's sit lower than the 04/05's did.
1st part, I'll raise the BS flag, sorry bud. It won't roll over any easier just because its on those narrow rims. It'll be fine. I run 13.50" wide TSL's on my Samurai on an 8" wide rim, I spin donuts all the time, its fine. It'll allow for lower tire PSI and the narrow wheel will help keep the bead. I can even spin donuts in my truck, with no worries about rolling over (unless its dirt and my m/t grip/tuck/and roll)
yes, the newer trucks sit lower, only in the rear, to help even off that super raked stance they came with early on.
And this might be a fine set-up for on road dirving, but I guarentee it'll rub when your off the beaten path, especially at full lock.
I also wouldn't be running the tires 5 psi over suggested tire pressure. Not safe, plus will lead to un-even wear of the middle of the tread. I can promise you that. My 2 cents.
wonder, maybe we could get a pic or two of the CV angles ? The upper ball joints ?
Love the stuffed wheel look BTW, looks beasty.
Old May 30, 2008 | 01:59 PM
  #35
ATOM's Avatar
my point is the center of gravity is alot higher. i shoulda made that more clear in my post. there's a reason rize recommends running a 4.5 backspace, to make a wider track width. just because the tires fits the rim doesnt make it proper. either way i'd never do it, but to each his own i guess.
Old May 30, 2008 | 02:12 PM
  #36
Big50's Avatar
I still have to agree with MT. The reason being, the fact the truck is 8"s lower will help keep it from rolling over far more than a increased track width. i also believe rize recommends a 4.5 backsacing to prevent the tires from rubbing the control arms.
I am having a tough time believing this setup. There has to be a lot of rubbing when he tries to turn.
Old May 30, 2008 | 02:16 PM
  #37
I gotcha....
but I still don't think it would be that big of a worry. ALthough I sure do like my wide *** stance on the 4.75" BS wheels
Old May 30, 2008 | 03:14 PM
  #38
duece212's Avatar
Rize recommends 4.5" on 17" wheels for clearance and "anything" for 18" and taller rims. I'm running 5.75" of backspacing and the wheels are tucked in pretty good. I shouldn't, but I've gotten on it decently around corners without problems. Now if I was at a bad angle offroad a wider stance might make me feel better, but I'm not too worried about it.
Old May 30, 2008 | 05:30 PM
  #39
JJDH's Avatar
it looks good ...i like to ruff house my truck so im ok with my tires .. he likes the tall tire. i asked him at least four more times and he says no rubbin.. he doesnt jump any bumps though[IMG][/IMG] [IMG][/IMG]
Old Feb 21, 2009 | 10:46 PM
  #40
wingman4's Avatar
ok... so I know I am posting on a thread that is almost a year old, but I really would like to see the CV axle and the upper control arm. Do you think you could post a couple photos of that? Thanks! I really do the look of that, it looks pretty beefy
Old Jan 24, 2010 | 12:32 AM
  #41
offroadn'98's Avatar
Alright, i know this thread is extremely old. But this is sooo Awesome/Amazing!!! I J***** my pants!!!
Old Jan 24, 2010 | 04:26 PM
  #42
IH8ATTN's Avatar
as for whoever said its unbalanced at a high height I am running stock wheels/tires on 8"'s of lift and I've taken on ramps/off ramps and there hasn't once a feeling that the truck is unstable. I plan to put on 35's as soon as I find a dirt cheap set but for now this is what I am using for the winter...yeah it looks gay but it makes up for the summer
