Tire/Wheel Question
Old May 28, 2008 | 07:31 PM
F150+Bronco=ME's Avatar
Tire/Wheel Question
Ok I have a 2.5" Leveling Kit for my 2004 NBS F150 2WD.
I want to get the Mamba M1 wheels in 17x8. (info on these can be found at tirerack dot com)
It says the offset is +25mm.....What does this mean? How far will the wheels stick out from where the stock wheels are?
I want to put the biggest tires I can as well so what is the best size to go with?
Rone
Old May 28, 2008 | 09:11 PM
JJDH's Avatar
simple 17x8 wheel ,center of wheel is 4in plus 25mm means the back hub of the wheel is 25mm forward or basically 1 inch so the backspace of wheel is now 5 inches instead of 4. that leaves 3 inches from the front of wheel where the lugs go to the lip of the wheel.. so measure from the face of your hub on the rotor out 3 inches and that will tell u how far out the wheel goes[IMG][/IMG]
Old May 29, 2008 | 01:54 AM
Is 3 inches a lot or is that normal? I don't want that goofy look that I see on a lot of F150s.
Old May 29, 2008 | 02:06 PM
JJDH's Avatar
Plus 25 Or 30 Is Good On F150
Old May 29, 2008 | 03:21 PM
wandell's Avatar
You may be able to fit a 285/70-17 with those wheels. You should have no problems with a 265/70-17.
Old May 31, 2008 | 09:05 PM
Im gonna go with 285/70 and just hope they dont rub. if they do I'll use it as an excuse to get a lift kit! THanks for your help everyone
