Another tire/rim combo fit question
Old May 21, 2008 | 12:59 PM
dhawk88's Avatar
I just got an AS 2.5" kit installed on my 05 f150 2wd. I am looking to put on 17x9 rims along with toyo a/t tires. I wanted to know if you think P285/70 (32.7x11.4) will fit without/minor rubbing or would the P245/75 (31.5x9.8) be a better route to go with?
Old May 21, 2008 | 03:06 PM
italiano's Avatar
i too have a 2wd and i am running 20x8.5 wheel with 6.1 backspacing and a 33-12.50 tire.your backspacing and wheel width is important.i got my advise from wandell and the specs i am running are the max.i do not rub at all.i have 2 inch level kitg and 1.5 aal.
Old May 21, 2008 | 04:31 PM
baldwinboy003's Avatar
i too have a 08 2wd....all i have is a leveling kit and i run 285/70/17....with no rubbing at all...u should be good...
Old May 23, 2008 | 05:41 PM
dhawk88's Avatar
I have changed my specs. How about a 17x8.5 rim along with 295/70 Nitto Terra Grapplers. Would that be a good fit with the 2.5" leveling kit?
Old May 24, 2008 | 02:01 PM
wandell's Avatar
It will depend on the backspacing on the wheels.
Old May 24, 2008 | 07:06 PM
dhawk88's Avatar
The backspacing is 5 5/16" (+15). Will that work? I have no idea what kind of backspacing is recommended or any of that.
Old May 24, 2008 | 10:43 PM
wandell's Avatar
They will probably fit, but it will be tight. The oem wheels are 7.5 inches wide with 5.5 inches of backspacing so those wheels will stick out about and inch farther than the stock wheels.
Old May 26, 2008 | 01:48 PM
dav700's Avatar
^^WTH^^
Old May 26, 2008 | 08:27 PM
wandell's Avatar
Spam.
